Castrol Syntec 10W30 Mitsu Montero 3.8L V6 7614 Mi Fram X2 Particle Count
Bay Area, CA
OK. I call this the Anti-Bitog oil test. I used the Evil Castrol Syntec 10W30 oil with the Evil Fram X2 (Extended Gaurd) oil filter (full synthetic element). The truck is a mixture of a grocery getter, kid mobile, mixed with some fairly long trips. A couple of observations. Look at those low Iron and Copper numbers for the Castrol. I know it is common for Castrol to show lower numbers than Mobil, but it is shocking to see such a dramatic change on your own engine. My Silicon number is nice and low and I still have the original air filter. When I inspect it, it looks fine. Just slightly darkened. The filter is about 2.5 years old. I don't see any reason to change it. Where is that Nickel coming from? Particle count is OK. I was interested because this is a full synthetic element. The numbers are not nearly as good as the recent M1 EP particle count. Insulubles are higher than they were with my last K&N filter. I have Penzoil Platinum in now, because it was cheap with the Pepboys rebate.
code:
               This      Last       Universal
              Sample    Sample      Averages
            (CS 10W30) (M1 5W30)
Mi/Oil        7614       6580
Mi/Unit      26,180     18,636
Make-Up Oil   0.5        0.5
Aluminum       3          5             5
Chromium       1          2             1
Iron           5          15            13
Copper         1          4             6
Lead           2          2             4
Tin            0          1             1
Moly           71         69            44
Nickel         4          3             1
Manganese      0          0             0
Silver         0          0             0
Titanium       0          0             0
Potassium      1          1             1
Boron          33         80            55
Silicon        8          7             10
Sodium         5          8             10
Calcium        2726      2582           2078
Magnesium      14         16            137
Phosphorus     691       864            804
Zinc           810       1010           943
Barium         0          0              1
Test :    Vis       Flash   Fuel   AFZ   H2O   INSOL
         @210F      Deg F    %      %     %     %
Shd Be:   58-65     >365   <2.0     0   <0.1  <0.6
This:     62.4      395    <0.0     0.0  0.0   0.3
Sampl
last:     60.7      390    <0.5     0.0  0.0   0.2
Sampl
This TBN = 2.8
Last TBN = 2.2
PARTICLE COUNTS
ISO Code: 17/13
Size of Particle		Count
>=2 microns			1969
>=5 microns			729
>=10 microns			202
>=15microns			78
>=25microns			18
>=50microns			1
>=100microns			0
Blackstone Comments: You added about 1000 miles to your oil change for this sample, and most wear improved. That's a very good sign that your Mitsubishi engine has no problems to speak of, and that you're treating it well. The TBN read 2.8, still showing some (not a lot) active additive left in the oil. The particle count read 17/13, clean for an engine oil. The number of particles present >=2 micron: 1969. >=5: 729. >=10: 202. >=15: 78. >=25: 18. >=50: 1. >=100: 0. We think your oil filtration system is working well and the oil could be run longer next time. Try 8000 miles.
Arizona
I agree with Pablo. Nickel would be from an alloy. If I had to bet money on one of my guesses I would guess its coming from the camshaft. The nickel reading is low. I would be more concerned about a tin reading then nickel.
WA
Winston can you list out more info about particle count you got with other oil / filter / mileage combinations? Did you use M1 EP oil with K&N filter combo. on your last run? Very intersting. Thanks for spending the bucks to do the particle count.
Winston
Bay Area, CA
Oops forgot to put in the dates. The old Mobil 1 sample date was May 12, 2005. The oil was in about 8 months old. The latest sample was taken on Feb. 1, 2006. So that is about 8.5 months. As far as the last filter (K&N) I did not do a particle count. The last oil was the regular M1, not the EP. I think it was SL. The M1 EP particle count that I was referring to was done by someone else on a different engine. So, it does not compare directly, but I think it still is usefull data. Here is a thread with a bunch of particle counts. Particle Count Thread
