GOLD IS GOOD!
This is my second UOA done on this engine - prior analysis was done on Lubro Moly Voll-Synthese (5w-50) nearly 50k miles ago. That analysis along with assorted comments can be found in this thread:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001353#000000
I've used Lubro Moly until my last couple of oil changes - this test is from my second change using Gold GC, the first fill being changed after about 5,000 miles. I'm pleased, and will probably continue to use this oil as long as I can find it.
I've collected what I can for GC VOA results, but have found conflicting sodum results 14 and 4.
![[Happy]](/forums/graemlins/fruit.gif)
code:More Comments to come - will add to this post when I receive Terry's interpretation of these results.1997 Passat VR6 Sump Capacity: 5.8 Quarts Type of oil Lubro Moly Castrol Univ-Avg Castrol Voll-Synthese Syntec Syntec GC-GOLD GC-GOLD Weight 5w-40 0w-30 0W-30 Date 03/07/04 09/10/05 Miles on engine 234074 281289 Miles on oil 7414 5238 0 - VOA Makeup Oil 1.5qts 2.0qts Aluminum 4 2 4 <1 Chromium 1 1 1 <1 Iron 15 10 17 3 Copper 2 4 5 <1 Lead 12 9 4 <1 Tin 1 1 1 <1 Molybdenum 4 11 40 <1 Nickel 1 0 1 <1 Manganese 1 0 2 <1 Sliver 0 0 0 <1 Titanium 0 0 0 <1 Potassium 0 0 1 12 Boron 89 12 61 <1 Silicon 4 3 6 4 Sodium 3 4 4 14 Calcium 1938 1752 2353 1941 Magnesium 383 406 205 770 Phosphorus 772 730 787 903 Zinc 905 765 939 1157 Barium 0 0 4 TBN 4.4 7.6 9.03 SUS Visco @210: 70.7 68.9 [email protected] Flashpoint: 380 390 Fuel %: 0.8 <0.5 Antifreeze %: 0.0 0.0 Water %: 0.0 0.0 Insolubles %: 0.4 0.3
