Hi Everyone,
This is my first UOA so any advice is greatly appreciated. I'm from Singapore where the weather is warm and wet. 80% of distance covered is on freeway. This isn't the German Castrol SLX everyone is talking about. It's beer colored and the label says ACEA A1/B1.
Silicon seems a bit high so I'm wondering if its my K&N drop-in air filter letting in too much dirt. Interpretation says it's most likely due to seal and gasket reaction.
I've just changed to Royal Purple 10W-30. RP costs about half the price of the SLX over here. Wonder how that will compare.
Car : 2001 1.6l Toyota Corolla (3ZZ-FE engine)
Oil : Castrol Formula SLX A1 0W-30
Miles on Oil : 6,400
Miles on Engine : 37,623
Metals (ppm)
Aluminium (Al) 11
Copper (Cu) 1
Chromium (Cr) < 1
Iron (Fe) 8
Lead (Pb) < 1
Tin (Sn) 1
Nickel (Ni) < 1
Contaminants / Additives (ppm)
Silicon (Si) 56
Boron (B) 15
Sodium (Na) 7
Potassium (K) 7
Phosphorus (P) 924
Molybdenum (Mo) 334
Magnesium (Mg) 13
Calcium (Ca) 2514
Zinc (Zn) 1134
Physical Tests
Total Base Number 3.7
Water (% by FTIR) 0.1
Nitration (Abs) 16.6
Viscosity (cSt,40°C) 57.2
Glycol (Abs) < 0.1
Petrol (% by Distillation) 0.8
[ October 23, 2003, 09:52 AM: Message edited by: es ]
Metals (ppm)
Aluminium (Al) 11
Copper (Cu) 1
Chromium (Cr) < 1
Iron (Fe) 8
Lead (Pb) < 1
Tin (Sn) 1
Nickel (Ni) < 1
Silicon (Si) 56
Boron (B) 15
Sodium (Na) 7
Potassium (K) 7
Phosphorus (P) 924
Molybdenum (Mo) 334
Magnesium (Mg) 13
Calcium (Ca) 2514
Zinc (Zn) 1134
Physical Tests
Glycol (Abs) < 0.1
