Castrol HM 5W-30 & 10W-30
Ottawa
Does anyone have the msds sheet for this oil?
I would like to know the actual vis of these oils at cold minus temps and hot temps.
Thanks all to who respond
I will have a UOA on GTX HM 5w30 in October, from my mom's 94 Probe GT. It has been in her car since the spring, and will have roughly 2000 to 2200 miles on it by then. (lots of short trips)
At work, I can get to the MSDS for almost any Castrol motor oil.
Castrol GTX High Mileage SAE 5W-30
SECTION VI: PHYSICAL/CHEMICAL CHARACTERISTICS
Boiling Point: ND Specific Gravity Water=1: 0.87
Vapor Pressure mm.Hg. @ 25 C: ND Vapor Density Air=1: ND
Percent Volatiles: Negligible Evaporation Rate BuAc=1: < 0.1
Solubility in Water: Negligible Freezing Point: -33 C
pH-Value: NA Viscosity @ 100 C, cSt.: 11.0 typ.
Odor Threshold: NA Coefficient of Water/Oil Distribution: ND
Appearance, Odor & Physical State: Clear, amber liquid; mild odor
Castrol GTX High Mileage SAE 10W-30
Boiling Point: ND Specific Gravity Water=1: 0.88
pH-Value: NA Viscosity @ 100 C, cSt.: 11 typ.
Les
Les, how about the 0w-30 from Germany? MSDS, and anything else you can get.
Edit: Never mind re: MSDS--saw it in your other post.
But what else can you get on this oil? Data specs?
[ August 30, 2003, 03:47 PM: Message edited by: YZF150 ]
For YZF150:
CASTROL FORMULA SLX surpasses a wide range of specifications
and has numerous manufacturer approvals including:
American Petroleum Institute (API) Service Classifications:
Petrol SL (SJ, SH and all superseded classifications).
Diesel CF (recommended for all diesel engines used in
passenger vehicles and light commercial vehicles,
including turbocharged diesel engines).
Association of European Automobile Constructors (ACEA):
A3 (Stay-in-grade, extended drain intervals for high
performance petrol engines).
B3 (Stay-in-grade for high performance direct injection
diesel engines).
BMW Longlife Oil and M51 Diesel Engine approved.
Mercedes Benz 229.3
Rolls Royce.
All Porsche cars (approved).
Team Toyota Europe.
VW 502.00, 503.01 and 505.00 issue (11.92).
SAE Rating 0W-30
KV @ 100oC, CSt 12.0
KV @ 40oC, cSt 68.4
CCS @ -35oC, cP 5,200
High Temp High Shear Viscosity 3.6
Pour Point oC -54
Base Number, mgKOH/g 11.0
Les
