In typical grades of 5W20 , 5W30 & 10W30 what differences between these two oils (bean vs. dyno) would one see specification wise as well as the add pack ? Any drawbacks to either one based on your experiences ? Wear protection , cleanliness and low volatility would generally be key criteria for me . At one time the PYB appeared to have almost a cult following due to low volatility , good amount of moly and good cleaning ability - but that was 3 to 4 years ago when the Pure Plus technology for synthetics (base) may have found their way into the PYB - not sure if the PYB specs. are that good still ? As for the Castrol GTX - I know the least about this oil but some indicate there may be some engine varnish issues if not changed slightly early . Again , your thoughts and experiences between these two conventional oils ? Thanks in advance !
