After searching this site for the best mineral oil to run my new ChevyZZ4Small Block on,I finally decided on plain Castrol GTX 10W30.
Bear in mind this engine has only ever run on a dyno over in the US but i am told is fully broken in.
I want to make sure that I also go easy for a few hundred miles to ensure the engine is run in properly.
Many people say to use a straight 30 weight to bed everything in right.
I know that i should use a non synthetic oil for the first few thousand miles and i also know not to run this new engine in with an oil that has a load of "slippery"additives.
On the GTX bottle it says 33%less engine wear than competitors oil.Does this mean it has these additives or will i be ok to carry on and use it?
thanks for your help guys
PM
