Received my latest sample, this was running GC 0w-30 in a Dodge SRT4, turbocharged 2.4 L engine, for 5900 kms, which is just over 3,500 miles I believe. I typically run OCI's between 3,000 and 5,000 miles to keep the warranty guys happy.
This is a very simple elemental analysis, nothing fancy for $14 cdn, CAT labs. SOS Fluid Analysis.
Iron - 8
Aluminum - 1
Copper - 1
Lead - 0
Moly - 97
Zinc - 687
Silicon - 11
Viscosity - 10.4 cst
Wear metals looked good, very similar to runs I have on Mobil1 10w-30 and Redline 10w-30, I wouldn't say any better or any worse. But I was very surprised on the end viscosity, it has sheared down quite a bit. My Mobil1 sample had visc. of 10.1 after 5500 kms., and my Redline 10w-30 sample had a viscosity of 10.8 after 7700 kms. It appears that the Castrol GC 0w-30 has sheared down a fair bit considering it starts at a very thick 30 weight , approaching 13 cst ?.
The Moly in the GC sample is left over from my last Redline run, so it probably benefitted a bit from having a decent dose of Moly in it from the previous sample. I liked the fact that the Castrol GC had less oil consumption than the other oils I've run, other than that nothing out of the ordinary. There were other metals tested by lots of zeros in the analysis so I left them out. I believe this engine uses aluminum bearings, perhaps combined with copper ? (not sure) so there is no lead detected in case anyone
notices the low lead reading. Either way the bearings are being well protected particularly on a turbo application such as this, which runs up to 19 psi boost.
Joey
Iron - 8
Aluminum - 1
Copper - 1
Lead - 0
Moly - 97
Zinc - 687
Silicon - 11
Joey
