Changed it sometime this winter with GC and a UPF-52 filter.
Previous fill and filter was the same but not tested.
First sample of 9/2/07 was Valvoline 10W-30 most likely with a cheap filter from my mechanic after fixing some oil leaks.
Wix air filter. Air filter changed at approx. 92k miles on the odo.
Blackstone Coments:
Silicon dropped nicely, so the sealers used during the work are washing out. Lead did not improve. Even when you factor in that this oil was run more miles than the last, lead increased on a per-mile basis. This shows bearing wear is increasing in your Roadmaster, which isn't good news. We'll assume that you'd like to hang onto this car, at least for now, so we suggest trying different oil. No harmful contaminants were found, so maybe the oil doesn't agree with the engine. There's nothing wrong with this oil in general though. TBN=3.6.
Comments welcome. I've got GC in it again with a AC Delco Gold UPF-52 filter. Not sure where to go from here. I bought the car 2 years ago with 90k miles and did an Auto RX double clean/rinse cycle on it then. I then switched to GC for 1 change before getting some oil leaks fixed and then the oils mentioned above.
Code:
OIL GC 0W-30 Valv. 10W-30
MILES IN USE 5.6k 4.6k Uni Avg
MILES 118k 108k
SAMPLE TAKEN 7/28/08 9/2/07
ALUMINUM 6 6 7
CHROMIUM 1 1 2
IRON 19 22 38
COPPER 4 5 12
LEAD 32 19 13
TIN 0 0 2
MOLYBDENUM 7 15 49
NICKEL 1 1 1
MANGANESE 1 0 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 1 9
BORON 5 7 42
SILICON 29 94 24
SODIUM 7 8 24
CALCIUM 1648 1701 1935
MAGNESIUM 526 66 270
PHOSPHORUS 868 616 791
ZINC 1054 737 954
BARIUM 0 2 1
SUS VIS 210ºF 66.2 59.3
cSt @ 212ºF 11.95 10.02
FLASHPOINT ºF 385 390
FUEL % TR
ANTIFREEZE % 0 0
WATER % 0 0
INSOLUBLES % 0.3 0.3
TBN 3.6 2.6
Blackstone Coments:
Code:
MILES 118k 108k
ALUMINUM 6 6 7
CHROMIUM 1 1 2
IRON 19 22 38
COPPER 4 5 12
LEAD 32 19 13
TIN 0 0 2
MOLYBDENUM 7 15 49
NICKEL 1 1 1
MANGANESE 1 0 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 1 9
BORON 5 7 42
SILICON 29 94 24
SODIUM 7 8 24
ZINC 1054 737 954
BARIUM 0 2 1
FUEL % TR
ANTIFREEZE % 0 0
WATER % 0 0
TBN 3.6 2.6
