This run had fewer miles and shorter trips. Oil was run over 6 months. No oil added. Pretty much on the same point it was on the dipstick when I changed the oil. Maybe the shorter trips led to the slightly higher fuel dilution...
Silicon is still at a good level. Air filter has been in for over 18k miles. It's staying in another 6 months. I'll look for rising silicon at next UOA and change the filter if that happens.
Viscosity dropped almost 2 full centistokes. Maybe the 1.7% fuel had a little to do with it, but maybe this engine also shears the oil too.
Plenty of TBN left. The oil probably could've gone past 10k no problem based on the TBN and oxidation only climbing 5 pts.
The virgin analysis for this oil is in the BL line.
Sample#1 was unknown dealer oil.
Sample#2 was Castrol Euro 5W30 API SL
Sample#3 was Castrol Euro 5W40 (same as current oil).
