This is my first UOA on the S4. A little history...I bought her with 68k miles in June '10 and is currently at 90,xxx. She consumes oil, unfortunately. The service records never indicated the previous owner complained about oil consumption. Consumption ranges from 200 - 500 mi/qt depending on the oil used. TCW-3 in the gas helps minimally. Oils I've used (in order of use):
M1 5w40 TDT (~500 mi / qt)
Rotella T5 10w30 (~500 mi / qt)
PYB 10w40 (AutoRX) (~500 mi / qt)
Rotella T6 5w40 (~500 mi / qt)
Castrol 5w40 (~400 mi / qt)
M1 10w40 HM (~200-250 mi / qt, the worse out of the bunch)
The BHF 4.2L is known for consuming oil and commonly due to cylinder wall scoring. We took a scope and looked at each cylinder but found no signs of scoring. We did notice a lot of carbon on the tops of the pistons, basically covered. A thought was that the piston rings are coked in carbon. AutoRX did nothing to help the issue, maybe cleaned out the valve train. It was quite clean when I did the valve cover gaskets. A piston soak using Seafoam did not help either (done early on). It cleaned off some of the carbon on the pistons at that time but has since returned.
I did a compression test and it was within spec. I don't have the numbers in front of me to reference. Once some oil was added to each cylinder and re-tested, the numbers did shoot up.
This past weekend, I ran BG 109 in the oil before changing it out. I've read several success stories on here helping to reduce consumption and restore some compression, if gummed up rings were the issue. After putting some miles on, it definitely feels peppier compared to before. I should note that I never felt it was down on power before. She pulled hard before the BG treatment but now feels even better. Maybe it's in my head. I checked the level after 150 mi and it's 1/4 low. Signs of improvement however time will tell. Current fill is GC 0w30. I've basically been buying what's on sale from AZ or AAP.
Sorry for the long read but thought it would be good to provide the history. The report from Blackstone is below. Per their comments, there's nothing that jumps out as the cause for consumption. Thoughts? Comments?
