CASTROL NORTH AMERICA INC.
CONSUMER MATERIAL SAFETY DATA SHEET
SECTION I: IDENTITY
Product/Material Name: Castrol Syntec Full Synthetic SAE 5W-40 Motor Oil
Chemical Name: Mixture
Chemical Family/Classification: Synthetic hydrocarbon
INGREDIENTS - CHEMICAL/COMMON NAME EXPOSURE LIMITS -
TLV
LD50 LC50 %
Synthetic hydrocarbons and neutral oils which
may contain one or more of the following:
CASRN 68037-01-4, 64742-54-7, 64742-65-0,
68649-12-7, 64741-88-4, 72623-87-1, 92062-09-
4
TWA: 5 mg/m3
Suggested
Oral, rat: > 5 g/kg. ND 70-100
Multi-functional additive mixture composed of
organo-metallic compounds, typically containing
zinc dialkyl dithiophosphate, calcium salts of
alkylated phenol sulfides, magnesium
sulphonate, alkylated diphenyl amines, and other
proprietary.ingredients CASRN NA,
Mixture
ND ND ND 15-30
SECTION VI: PHYSICAL/CHEMICAL CHARACTERISTICS
Boiling Point: ND Specific Gravity (Water=1): 0.85
Vapor Pressure mm.Hg. @ 25C: ND Vapor Density Air=1: ND
Percent Volatiles: Negligible Evaporation RateBuAc=1: < 0.1
Solubility in Water: Negligible Freezing Point: -22F to -40F -30C to -40C
pH-Value: NA Viscosity @ 100C, cSt.: 12.8 typ.
Odor Threshold: NA Coefficient of Water/Oil Distribution: ND
Appearance, Odor & Physical State: Clear, amber liquid; mild petroleum odor
Flash Point COC: 437F 225C min.
Fire Point COC: > 450F 232C min.
Section 313 Toxic Release Inventory Chemical/Category:
Zinc compounds, 2.5% wt. max.
