Castrol 0w40 without LL-01 in BMW S63
Colorado Springs
If you're talking about the rear upper shock mounts, the Monroe's are a nice upgrade. Not huge but worth it. I don't know much about rear lower mounts or front strut mounts though.
Yeah, that is what I am talking about. Will see, I might get complete set up with B4. Though I might go M3 bushings on subframe.
Ontario, Canada
No, I do not mean to buy Monroe shocks. I am going with Bilsten B4. However, from what I have read on BMW forums those that used Monroe mounts, it seems that it provides better responsiveness to a car once moved to regular tires from RFT's. As I am going to do some track days once this crisis is gone and my in laws can watch kids, I will need to do some work on suspension. But, as this is my DD, I am not going to crazy.
Yes, the Monroe rear upper shock mount bushings are a good upgrade, but that is the only thing Monroe I would use. I have the M3 subframe bushings in my 1 series, worth every penny. Ridiculous how bad the stock bushings are. On my E90 I just used the inserts, not as stiff as the M3 bushings, and transfer more noise,, but can be installed in 30 mins.
NJ
What does the BMW crowd think of bimmerworld's endorsement of Red Line oils?
BimmerWorld Oil Recommendations
We've put together some suggestions in the table below based on intended use, an oil change interval of 5,000-6,000 miles, and our own preferences from over 20 years in the BMW tuning and racing world. Our "go-to" oil is unquestionably Red Line synthetic because we have seen its superiority first hand in our customer and race cars. "
Colorado Springs
Marketing. Redline is good oil, especially if track is taken in consideration.
But, Redline is not approved oil. Approvals are cheap, and question is: why no approval?
One thing is to use oil that is approved for MB229.5. But Redline Performance is not approved for single specification.
I would use it on track, without hesitation.
Ontario, Canada
I have the same engine as OP and use Castrol 0w40, pennzoil euro and Mobil 0w40. All are great oils. I change oil often as these engines generate A LOT of heat.
As for the discussion on suspension I put B4s on my E90, was a nice upgrade. In hindsight I think the b6s might have suited my preferences better.
propellerhead78
Fullerton, CA
It certainly does throw a tremendous amount of heat! I almost always open the hood after I get home to help it escape. It heats my garage up quite a bit!
What's your OCI? I'm doing 3.5-5K depending on how long it's been in there, 6 months max. The OEM (//M) filter costs about the same as the Mahle part so I've stuck to that though there's no real difference.
FL
Is Redline paying BimmerWorld for sponsorship?
Ontario, Canada
I have also opened the hood now and then lol.
I usually change oil at 5000 km ( 3000 miles). Some can think it's over kill but I like the piece of mind particularly with some of the issues these motors run into.
propellerhead78
Fullerton, CA
I have used Redline drive line oils for over a decade in a number of different cars, but only used their engine oil (5w40) once in our TT. I used D4 ATF in our manual trans equipped E90 (as recommended by Redline) for well over 100K, changed at 50K intervals. Great stuff!! I have MT90 in the TT and 2002 gearboxes with Redline 75w90 in the '02 rear diff. The TT feels as new and the '02 (with over 300k on it) retains a modern car-like shift feel.
Very satisfied with their drive line oils and I try to follow the 'Old School" maintenance plan from Mike Miller. These fluids retain great performance through those intervals.
Colorado Springs
I use their drive line oils in my Toyota, and will use it in my BMW, manual transmission and differentials. While their engine oils are without doubt excellent products performance wise, I am not so sure in daily use considering price tag of cat's on BMW. That is where approvals come handy to remove any doubt.
NJ
I had no idea the X3 M40i calls for a 0w20. Red Line 0w20 has a HT/HS of 2.9, but of course, no approvals. I'd like to see a data sheet for the BMW 0w20 oil.
FWIW, the guys at bimmerworld said they noticed much better engine cleanliness with Red Line and engines do last longer.
Colorado Springs
BimmerWorld and RedLine are in partnership. Maybe BMW asks Bimmerworld to approve oils?
