Castrol 0w-30, 8420, 09 Subaru Legacy 3.0L
Edgewood, KY
Code:
DT SAMPLED 01-Jan-17 02-Dec-15
DT RECEIVED 13-Jan-17 17-Dec-15
DT REPORTED 16-Jan-17 19-Dec-15
TIME ON UNIT 109,083 93,804
TIME ON OIL 8427 7134
OIL BRAND Castrol Castrol
OIL TYPE Syntec Syntec
OIL GRADE 0W-30 0W-30
OIL ADDED
FILTER Amsoil Amsoil
OIL CHANGED
Metals (ppm)
Iron (Fe) 7 7
Chromium (Cr)
Lead (Pb)
Copper (Cu) 2 2
Tin (Sn) 2
Aluminium (Al) 4 3
Nickel (Ni)
Silver (Ag)
Titanium (Ti) 42
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 16 12
Sodium (Na) 10 5
Potassium (K) 3 7
Additives (ppm)
Magnesium (Mg) 513 526
Calcium (Ca) 1853 1789
Barium (Ba)
Phosphorus (P) 926 872
Zinc (Zn) 1068 1049
Molybdenum (Mo)
Boron (B) 8
Contaminants
Water (%)
Coolant No No
Physical Tests
Viscosity (cSt 100C) 12.6 11.4
Physical / Chemical
Base Number (mgKOH/g) 4.6 6.0
FYI: Had fuel injectors cleaned around the 103,000 miles.
Ti doesn't make a bit of difference, at teh same time it seems the reformulation did not reduce quality of the oil either. Great report, thank you.
8 posts in 13 years.. that struck me more than the report
Yeah, he's a little chatty this year.
You’re to kind. I finally changed the oil after all these years. I have preferred to imitate the NSA in the past. Just snooping around in the background. I could say, “I was at work, or was I out fishing.” BTW: The wife tells me, “I say too much.” Just a heads up, I even plan to post again later this year. Oh, now I’ve gone and said to much.
OP, Thanks for the UOA, it's good to see a Euro A3/B4 oil tested, and good to see the difference between the Castrol Edge both with and without Titanium.
Both performed very well, nice low iron numbers.
