@candyman123
Use the open container oil as a small equipment lube. Like mentioned before, lawnmower etc.
If there is another container, not opened, and the specs either meet what your needs or are not important, use it with confidence.
Not that I could find. First I couldn’t find the code. I don’t get here often but have been here since 2020. I did see about date codes but they were all in the single digit (2008,2009 etc). I wasn’t sure if it was a 2020 code, so I asked
Use it mowers. They'll run forever on non-detergent 30. Even "expired" oil is better than they need.
I've put 5 year old oil in a Mercedes and it didn't hurt it.
In before the lock.
