I numbered some portions of the previous post.
1.) I wanted to normalize for displacement too, as it seems that 3 liter engine with a 6 qt sump would produce less wear metals than a 6 liter engine with a 6 qt sump.
2.) The 'wear rate' in the 2nd column is iron per 1k miles, which seems to be a common way a common way of looking at wear metals over different intervals. Everyone seems to stop at this point and draw their conclusions, but an obvious problem is that one already stated that the average rate was 10.5 (at 1k miles), so it can't be 6.3 (at 2k miles). Since the average was 10.5 at 1k miles and it dropped to 6.3 at 2k miles, what was the rate from 1k to 2k miles ? The 1k to 2k mile interval had to be less than 6.3, as it was combined with 10.5.
By not determining what the rate was for each 1k interval, instead of just averaging out to the interval, we're throwing away the most important data. If the average is the same at every 1k interval then the rate for each 1k interval will be the same, but if it's not, then it's not.
3.) This data suggests that although there are more metals at duing the 1k interval than others (is it the first 100 miles ? 500 miles ? is it dissolving some previous films ?), one still sees about a doubling in wear metals from 3k to 4k, so a 3k oil change might be suggested.
1.) It's evidently a 5.7l engine with about a 6 qt sump. Looking at the iron rate normalized for sump + make up oil, engine displacement and mileage, we have the rates shown in the second column.
2.) We need to look closer though as the rate at 2k states 6.3 but that's different than the 10.5 rate at 1k, so we need to determine what the rate was for the second 1k miles, then the next 1k miles, etc., which is what we have in the third column.
3.) Since there is a big jump going from 3k to 4k, the data suggests that it's reasonable to change it at 3k. I'll take a closer look at how to determine the rates for each sample interval, as so far I've done it this way just because it's easy to do.
1k 10.5 10.5
2k 6.3 2.1
3k 5.3 3.3
4k 5.8 7.4
5k 6.1 6.9
6k 6.1 6.2
