Link
Lubricating oils, petroleum, C20-50, hydrotreated neutral oil-based, high-viscosity
Was wondering if this is quality oil for general lubrication, and what group this might fall under. It is in a product that I use, and the description is different than most. Any info would be appreciated.
Quote:
A complex combination of hydrocarbons obtained by treating light vacuum gas oil, heavy vacuum gas oil, and solvent deasphalted residual oil with hydrogen in the presence of a catalyst in a two stage process with dewaxing being carried out between the two stages. It consists predominantly of hydrocarbons having carbon numbers predominantly in the range of C20 through C50 and produces a finished oil having a viscosity of approximately 112cSt at 40.degree.C (104.degree.F). It contains a relatively large proportion of saturated hydrocarbons.
