CarQuest R95140 Cut Open
TN
This filter was on a 2017 Chevy Volt when purchased used and probably has fewer than 50 miles on it. The car was overfilled by two quarts when I got it, so I didn't trust any of the other work they'd done to it and changed everything at once for a fresh start. [Linked Image from i.imgur.com] [Linked Image from i.imgur.com] [Linked Image from i.imgur.com] [Linked Image from i.imgur.com] [Linked Image from i.imgur.com] [Linked Image from i.imgur.com]
Lyndhurst NJ
For the money you really cant go wrong with a carquest white can. They look much more better built than the napas.
HX520W
TN
Originally Posted by slacktide_bitog
Yikes that looks terrible! Already wavy after only 50 miles crzy What did you replace it with? smile
I replaced it with a Wix XP (which has the correct bypass setting) and filled it with Castrol Edge EP 0W-20. Over 75% of the 5,000 miles I've put on it have been EV only. The range extender is really only used for long highway trips, so it'll probably be following the two year OCI by the book.
