Quote:
Oil Changer, is it just MaxLife that is cheap or all Valvoline products?
http://www.pqiamerica.com/June 2014/consolidated highmileage2014.html
Everyone has their opinion, However if you look at the specs from the PQIA tests you will see that Maxlife is arguably the best HM oil tested. It has a strong TBN as well as a low Noack value, which is indicative of a good quality base stock, so it isn't "cheap" at all in terms of value. The issue your having doesn't sound like an oil related issue. Good luck in finding out what exactly is wrong.
