Originally Posted By: George Bynum
I've never seen any that doesn't throw in the number 32, 46, of 68 in the description. Those are the 3 more common ISO viscosity grades. Most claim AW for antiwear additives. That is important.
For my money, in a system operating below 1500 psi, most of the inexpensive stuff is ok. If higher, I'd recommend a fluid that is tested to one of more of the common manufacturer standards; Vickers (Eaton) has 2, and Denison at least 1.
Warren has been in business a long time and has a decent reputation. Their website lists a less expensive CUI family and a premium Coastal family. Both are available in the 3 viscosity grades above; Coastal extends that to 100 and 150, rarely used in industrial or mobile hydraulic systems.
Right,,anyway i went with a better oil i found some Shell Tellus 100, my unit works on 2500psi and below so im going with that should be good oil.
thanks....
Tellus is a suitable oil. ISO 100 is AWFULLY thick. You should not normally run at *any* time with an oil this thick unless the oil is at least 60F, and not at over about 100 psi until at least 120F. Normal operating range for this grade fluid is from 140F to 190F ... and life will be, by industrial multi-year criteria, short.
No oil cooler so when digging hydraulics gets hot!,,a 30w is perfect for this unit. anything else turns into water and hydraulics suffer performance. i've recorded 140 to 180 deg temps already and that was after only an hour of digging.
unit only operates during summer months,,no cool/cold weather operation.
