Hi,
after reading this thread about alternative oil filters for a motorcycle, I became interested in doing my own search for what I can get as an alternative for HF-204 (KN-204) oil filters in Reunion Island.
Here's what I found :
The only motorcycle filter brand we can have here (except from OEM) is Hiflofiltro, and the HF-204 is selling for like €15
From this, and looking at California Scientific's Oil Filter Cross Reference page, and then using Google and many filter manufacturer's catalogues, I'll use MAHLE part numbers to sum it all, from the most ressemblance to the most extreme (providing you have the right clearance around the filter mounting location)
Hiflo HF-204: OEM, €15
Mahle OC195: same size as HF-204, 1.0 bar bypass valve, can be bought at around €5 -- Mainly a filter for Mazda (121, 323...) engines (got a Klaxcar FH030Z for instance)
Mahle OC617: extra height (+20mm), 1.0 bar bypass valve, can be bought at around €6 -- Mainly a filter for Honda (Civic) engines. Beware, clearance, not much with front wheel but more with exhaust manifold (on some bikes, you can't put that filter on if the manifold is on)
Mahle OC115: extra height (+25mm) and weight (+10mm), 1.2 bar bypass valve, can be bought at around 7€ -- Probably sold here for much Kubota and Yanmar equipment. Check clearance twice (exhaust and engine block around the filter screw-on location) before buying (got a AMC MO-523 filter)
Is there something I'm missing ?
Attached is a pic of HF-204 vs AMC MO-523
