In June, the oil analysis for our 1999 Ford Ranger, 4.0 V-6, 69000 miles, oil mileage 7002, came back showing high amounts of copper (16), lead (8), potassium (22), and calcium (3443). Blackstone suggested possible coolant contamination, but the values were too low to be certain.
In July, we suddenly experienced missing and rough running, which was traced (by Ford) to the spark plugs. A new set of plugs and it’s run fine since.
At the next OCI (5308 miles in November), we repeated the oil analysis. This time, the abnormal values were copper (17), lead (9), potassium (209), sodium (95), and calcium (3042). Blackstone indicated with some urgency that we indeed had a problem. In addition to the abnormal values, they indicated moisture damage in the additives, a high viscosity reading (96.4), and antifreeze (.19 percent).
Ford ran coolant system pressure, compression, and cylinder leak down tests. The truck passed all three tests with flying colors. Ford says the motor is in great shape. We spoke with Blackstone and they were sure of their results.
We’re stumped and would appreciate any ideas y’all may have as to how we can get to the bottom of this. I’ve posted the full analysis values in the UOA section.
Thanks!
Ralph
Thanks!
Ralph
