Thanks for the replys
I found liquid wrench marine grease at Lowe's and was suprised
by it's specs. Not a bad grease for $6, compares to the Lubrimatic.....
TECHNICAL DATA SHEET
PRODUCT DESCRIPTION: GR015 is an Overbased Calcium Sulfonate grease, which is characterized by exceptional corrosion protection, high dropping point and mechanical stability. Due to its unique chemistry, GR015 provides superior protection against corrosion in harsh, corrosive environments. The very high load carrying ability, excellent resistance to water, oxidation and corrosion, and outstanding performance in a wide temperature range, make it a high performance premium grease. The Marine Grease contains no heavy metals or other harmful or environmentally undesirable additives, such as phosphorus, chlorine, zinc, phenols, antimony, barium or lead.
TYPICAL PROPERTIES:
NLGl Grade: 2
NLGI Certification: GC-LB
Soap Type: Calcium Sulfonate
Texture: Smooth
Color: Red
Penetration, ASTM D 217, worked 60 Stokes: 265 - 295
Dropping Point, °F (°C), Min, ASTM D 2265: 554 (290)
Copper Strip Corrosion,
210°F, 3 hrs, ASTM D 4048: 1a
Oxidation Stability, ASTM D 942 (100 hr., psi loss): < 1
Oil Separation, %, ASTM D 1742: 0.2
Timken OK Loads, lb, ASTM D 2509: 65
Four Ball EP, Weld Point, kg, ASTM D 2596, kg: 500
Four Ball EP, LWI, ASTM D 2596: 65
Four Ball Wear (Scar, mm) ASTM D 2266: 0.39
Water Washout, @ 175°F, % , ASTM D 1264: 2.8
Corrosion Protection, ASTM D 1743: Pass
Fretting Wear, mg loss, ASTM D 4170: 2.3
Low Temperature Torque, -40°C, Nm, ASTM D 4693: 7.6
High Temperature Life, hrs, ASTM D 3527: 100
Leakage Tendencies, g, ASTM D 4290: 6
Base Oil Properties, ASTM D 445
Viscosity @ 40°C, cSt: 100
Viscosity @ 100°C, cSt: 11.2
V.I. Min: 95
Pour Point, °C (°F), ASTM D 97: -18 (0)
Flash Point, COC, °C (°F), ASTM D 92: 224 (435)
CONTAINER DESCRIPTION: 15 oz wt. cartridge.
Distributed By:
RSC Chemical Solutions
A Division of Radiator Specialty Company
600 RADIATOR ROAD, INDIAN TRAIL, N.C. 28079-5225 / 704-821-7643, 877-GO-4-GUNK
NOTICE: While this information is presented in good faith and believed to be accurate, Radiator Specialty Company does not guarantee satisfactory results from reliance thereon. The data is offered solely for your information and Radiator Specialty Company disclaims all liability for any loss or damage from its use. Thoroughly test any application according to the product directions and independently conclude satisfactory performance. Nothing contained herein is to be construed as a recommendation to use the product in violation of any patent.
