Originally Posted By: KingCake
Originally Posted By: goodtimes
What does the center tube look like? The oil and filter don't look so dirty so why would it need bypass? Faulty installation or filter, probably. Delco may have upgraded the part number on this. I would get a filter at the Cadillac dealer and talk to them about it. GM made the car, the filter they use is the right one.
You realize cars go into bypass all the time, even with a new filter right? This is why a tiny tear in a filter media doesn't really matter.
There are two relief valves on car engines, not likely both defective at once. An oil filter center tube has to be able to withstand the relief valve pressure setting without collapsing.
A tiny tear on a filter means almost all the oil is unfiltered until the flow is enough to exceed back pressure or "delta P" through the media. Until that point is reached the tear is an unrestricted hole.
