Good point. I own a tiny tiny share of Walmart. I forgot about that, so I say I'm good to goAs part shareholder of Walmart Inc. (WMT) I hereby say no, you cannot not.
I don't think you were. You got what had to be done accomplished. I bet a lot of us had a hoooptie.... admit it or not!I can neither confirm, nor deny, that I have done fuel filter, spark plugs and wires in an auto parts parking lot. I was in the Navy and living in the barracks. It was 3 days before Christmas and I needed to get it done on my hoooptie before driving home (about 800 miles......)
I was stupid then.....
The actual process is probably 15 minutes. It's not a spin on filter, I have to remove the fender liner so I can access it on the side of the engine. Then use a 1/2 drive extension to loosen it which barely clears the frame. Then wrangle it off after draining the fuel out and disconnecting the wifi sensor and don't forget that remove the clip that holds the abs wire against the fender to keep it from flopping around. I also have the tire turned all the way to the left so I can sit inside the wheel well area while doing this, so if you're any bigger than my 125lbs, you're going to just hate life at this moment. Now if the truck was on a lift I could spin it off from underneath and it would be a very quick 20 minute job most likelyHow does it take an hour to swap a filter?
Your neughbor doing donuts in your dooryard 24x7?
oh yeah, everyone has atleast an acre out here. There is almost always someone mowing a yard off in the distance somewhere.It never seems to fail....
The few times I've had sensitive components opened up, my neighbor decides it's time to mow......
