OVERKILL
$100 Site Donor 2021
Originally Posted by StevieC
It may allow 20w50 but it might not be optimal for bearings. The reason they "allow" it is because there might be limited choices in certain parts of the world and the trade off could be minor wear/tear that results in using a less optimal thickness of oil. I'm talking 5w30 to 20w50 sort of scenario.
Based on Shannow's significant presentation on bearing design and operation, my takeaway is that you can't really go too thick on the bearings (within reason based on the W rating relative to ambient). They are self-regulating via side leakage and if anything a thicker oil just provides a more generous MOFT. What you do end up with is some more heat generated by the heavier oil as a result of friction, higher load on the oil pump drive assembly and higher oil pressure as an artifact of resistance to flow.
Conversely, to accommodate thinner oils there have been changes to bearing design which increase friction somewhat. The primary modification is bearing width as a lower MOFT can be counteracted via a wider interface.
