Quote:
Where are you seeing these particles?? Yes, sound like something to worry about.
On my engine at least (2003 transverse 1.8T), there is a plastic hose that comes up to join up with the rubber Y-Hose. The other branch of the "Y" joins up to a nipple on the valve cover. I saw those particles when I looked inside the plastic hose and the Y-Hose. Your engine may be different but see what you can take apart that is part of the PCV system. If you get a look inside, please let me know how filthy it looks.
I like your serviceability rating idea for cars. It seems that the really cool, performance-oriented cars are the generally the least serviceable. Turbo cars are especially bad!
Quote:
Agreed but then, most things they would want to look for are not readily available, would you agree? I mean, sure, you can look in the oil filler area, but valve train/timing belt etc are pretty difficult to "look" at.
The thing that helps is that the area you can see through the oil fill hole is one of the most deposit-prone parts of an engine, so if it is bad there, it's probably bad in the valvetrain too.
Quote:
I'm expecting mine to go. These things always seem to happen when we''re out of town. Had a fan-short keep blowing one of the fuses on the battery mounted box last time I was in West Chester, Pa. O2 sensors in Fla and N.C. I guess I was lucky I blew a coil and the transmission went both near home.
Man, that sucks. Mine has been much more reliable than that. Knock on wood...
Quote:
And yet ChiTDI loves GC. I guess it just depends?
Yeah, it does depend and it makes no sense to me because some oils have worked very well for one guy's engine and not in another guy's same engine type. Besides the 1.8T, a moderator here named ekpolk used to have an Infiniti G35 and GC worked so well in his. That convinced me to try it in mine. It burned it up at two to three times the rate that every other oil I've tried in it(M1 0W-40, Syntec 10W-30, M1 10W-30, Amsoil ACD). I gave GC approximately 15,000 miles (3 oil changes) to "settle in" in the engine and the oil consumption was actually worsening, not improving. It is a pain to check the oil in the G35 and oil consumption is not good for catalytic converter and O2 sensors, plus it costs money, so this was a deal-breaker with GC.
