code:1. Does the Final Drive Ratio mean the differential? Does it mean you turn the propeller shaft 2.74 times, the wheel turns 1 time? Or it is the other way around? 2. Does Gear 1 Ratio mean the engine turns 3.943 revolutions, the transmission output turns 1 time? 3. So if we put the tranmission and differential (Final Drive) together, Gear 1 Ratio of 3.943 and Final Drive Ratio of 2.74 means the Engine has to turn 3.942 x 2.74 = 10.8 times before the wheel turns 1 time? 4. So when the Engine is at 2000rpm in Gear 1 Ratio, the wheels are spinning at 2000/10.8 = 185rpm? So for say a 205/65/15 tire with a circumference of approx 2.03 meters, will be travelling at 185 x 2.03 = 376 meters per minute or 22kph. Is that correct?Transmission Type 4 speed electronically controlled automatic transmission (ECT) with lock-up torque converter Gear 1 Ratio 3.943 Gear 2 Ratio 2.197 Gear 3 Ratio 1.413 Gear 4 Ratio 1.020 Reverse Gear Ratio 3.145 Final Drive Ratio 2.740 Drive Type Front wheel drive
