Can someone please explain the differences between Group 1, 2 and 3 oils. And what brand/type oils fall into each Group. THANKS ![[Cool]](images/icons/cool.gif)
quote:...would appear to indicate ...that in any way anyone could choose to measure a multivisc oil ...Group III would be the choice by far. That is, NOT needing "enhancements" to perform in a broader range. So what's the "minus" to Group III that isn't with Group II?? Please apply the same "under 130 IQ filter for the explanation.
Removing the sulfer and aromatics to single digit parts per million results in better oxidative stability. Waxes, per se, are actually great lubes - in their liquid state. Their problem is that they crystalize out at relatively high temperatures compared to true oils, so cold weather operation becomes problematic because of gelling in the sump. Don't confuse "paraffin" with "wax". "Paraffin" is a type of organic compound, not a specific substance. "Waxes" are only one sub-category in the extensive list of "paraffins". Simultaneously, concentrating desirable paraffin base lube stocks in the entry volume results in higher quality base lube stock due to higher viscosity indexes (greater inherent viscosity range requires less VI improver additive).
quote:If you go in Wal-Mart and look at the the oils on the shelf, the only ones that you can pretty much count on being all or mostly Group I are the straight 30 weights (and 40s if there). All "regular" 5w30s will be Group II/II+, while 10w30 and 10w40 will have Group II and MAY have some Group I. HDEO oils MAY have some Group I in them as well. Most "synthetic" oils, with the exception of Mobil 1, will be all Group III, or they may be Group III with SOME Group IV.
Originally posted by Pro3qtr: What oils are group 1,2,3 ??![]()
quote:I'll second the question ...but I'll add: Most of us haven't had chemistry since high school and are very glad that we haven't since. We haven't had the need to figure out what a PAO is ..nor likely have the ability to understand the marvel of these three little letters. We can probably save you the exercize in demonstrating your vast knowledge in such chemical properties ...and ask that you merely state them "for effect". We don't typically know the value of "it has a high carbon ring in its molecular string" ..but could easily understand "that means it will do xxxyyyy in this situation and zzzzqqqq in that situation. That is, Keep It Simple Stupid K.I.S.S.
