Originally Posted By: laserred96gt
What about the filter ? How often ?
If it's an external filter, I have it replaced at 10k miles. At the same time, I get a lower return line off with the engine warmed up, and let the ATF flow out while simultaneously refilling from above. When the draining fluid changes in color, I stop and reconnect the hose. This may take 10 - 12 quarts total. Thereafter, I'd do a drain and refill every 40K. No more filter change for the life of the vehicle.
If there's an internal filter, I wouldn't touch it unless the auto trans pan is off for another reason.
