Originally Posted By: Stu_Rock
I think there needs to be a clarification about what's meant by "notchy."
Are there certain steering angles where steering is more difficult? Are the angles always the same, or does a "notch" appear at random angles? Is it the same turning left or right?
But since it's still under warranty, it might be best to refill with GM 89020661 (or something with the same look and smell) and let the dealer fix it.
Edit: It looks like GM 89020661 might be relabeled Chevron Havoline power steering fluid. I'm maybe 65% sure of that.
It's notchy when cold, and it's when i'm backing out of my driveway turning left that i've noticed it. I beleive it does it while turning right as well, but i'm not 100% sure. I'm not parked at much of an angle, but it is a slight tilt to the right.
I couldn't imagine this to be an issue, but i don't know. There is plenty of fluid in it, so that shouldn't be an issue.
I've always been leary of GM's PS systems, as my dad always had issues in the past with them. This is the reason why i've never put ATF in it, as i'm sure they would deny coverage if there was a problem.
