can i mix 5w30 with 10w30?
i have gm 5w30 oils in the engine.i was thinking to put gm 10w30 in it,about 1/2,1 quart.is it ok,or should i only add 5w30
I've even mixed straight 30 weight in with 10w30 and no apparent problems. Oh, I've mixed worse things than that too.
how about mixing 76 super synthetic blend about 1/2 or 1 quart to gm dino 10w30 4 quarts?
The net effect of adding 1/2 or 1 gt of anything
in your 4.5 gt really doesn't change it much
as you can check in the shell viscosity mixer as its only changing it by 1/5 anyway. I do use add oil to aim the grade to where I want to try.
On my daughter's oil consuming tercel, I add 1 qt of 20-50 Castrol HM to see if thicker helps stop her consumption and rear main leak. On mine I add some moly laden VSOT or 10-40 to see if moly or thicker helps. Its like a low cost preview if you are going to change in 1k miles anyway.
On yours, you will change soon if you stay with 3K OIC so adding a blend with maybe 20% syn is like adding 5% syn. If you want to experiment and see how a blend works with GM dino I'd add all syn so at least you get a blend for the entire 4.5 gts. Costwise I'd add any dino since you'll drop it in a month.
