Can German Castrol 0w30 Cause Sluggishness Over Mobil1 10w-30 ?
Ontario , Canada
Not sure if this is just in my head but since switching to GC 0w-30 coupld days ago over Mobil1 10w-30 which I ran previously the car seems to be more sluggish in its operation. I know GC has more hot viscosity, is there anything else between the oils that could result in this feeling. My engine has balance shafts down around the oil pan, and there isnt any windage tray either on this engine. I just think the engine was a bit more eager to rev when it was running Mobil1 10w-30, perhaps it has less friction compared to GC. Any opinions or thoughts on this. Lastly I could just be dreaming all this up as well, dunno. thanks Joey
Tampa, Florida
Well, all I can give is the stats on the oils. I will let the experts elaborate on them. We do know that the GC is on the thick side of a 30w and the M1 is on the thin side. I have experienced the same thing when going from M1 10w30 to Amsoil 10W30 on my spouse's car. Switched back to M1. GC 0w30 cSt 40c=68.5 cSt 100c=12.2 M1 10w30 cSt 40c=62 cSt 100c=10 [ April 10, 2004, 07:14 PM: Message edited by: pruizgarcia ]
Idrinkmotoroil
Ontario , Canada
thanks, yeah that looks like a big difference in viscosity, my engine also has oil squirters for the underside of the pistons and an oil cooler, not sure if they are affected by oil viscosity. I keep thinking about that Quaker State commercial where Rick Hendrick from Hendrick Motorsports reports that Quaker state has reduced friction levels by a certain percentage in their oils and he needs that extra edge in his racing motors for more hp etc....., wonder how much difference there really is in friction control between different oils. I guess one way to affect friction is through viscosity.
Idrinkmotoroil
Ontario , Canada
quote:
Originally posted by Technarch: Not your imagination. I noticed this too on my 4-banger Focus.
mine's a 4 banger too, Dodge SRT-4, wonder if smaller engines make it more noticeable. ?
Greece
Probably it is not your imagination. I remember a few years ago when i was using a 10W40 and switched to mobil 1 15W50 . It felt a little sluggish in the first 500 miles but after that the performance was way better. It must be something really nice in their formula [Smile]
Patman
Staff member
Oakville, Ontario
In both of my cars, GC is a thicker oil at operating temp than what used to be in them, but in both cases the engines feel like they've got more low end and midrange power.
Patman
Staff member
Oakville, Ontario
quote:
Originally posted by yannis: Patman...what time do you get up in Sunday mornings??? [Big Grin]
I slept in until 5am today, I'm usually up at between 4:15 to 4:30 everyday, including weekends. I'm just an early riser! [Smile]
Southern NJ
My guess is that it's either the higher viscosity of GC or it's not as friction modified as M1. Redline made my engine run smoother then any other oil. ASL/M1 are about the same.
Idrinkmotoroil
Ontario , Canada
well I decided to remove the GC and I saved it for use in my other vehicles that likely need the extra visc. . I've gone back to Mobil1 10-30 (4 qts) with a quart of Redline added to the mix [Wink] . I got the go-ahead from Dave at Redline so what the heck, might as well try this experiment. I can definitely notice a difference in back to back runs of GC and Mobil1, the Mobil1 seems to free the motor up where GC felt sluggish. Joey [ April 11, 2004, 06:14 PM: Message edited by: Idrinkmotoroil ]
Washington, DC
speaking of difference betwwen GC and M1..If the thickness of GC over M1 10W-30 is to blame for power loss how would you explain this then? M1 0W-40 produces more power then lighter weight GC 0W-30??? CASTROL SLX 0W-30 SYNTHETIC RPM 3000 3500 4000 4500 5000 Ft-lb 262 290 301 293 272 HP 149 193 229 251 259 Maximum HP: 263.7 @ 4900rpm Maximum Torque: 314.2 @ 3750rpm Oil temp: 175FOil pressure: 43-55psi Water temp: 186F MOBIL 1 0W-40 SYNTHETIC RPM 3000 3500 4000 4500 5000 Ft-lb 268 311 304 300 283 HP 152 207 231 257 269 Maximum HP: 270.5 @ 4950rpm Maximum Torque: 318.3 @ 3700rpm Oil temp: 206F Oil pressure: 52psi Water temp: 190F http://www.performanceoilnews.com/oils_against_oils.shtml
Idrinkmotoroil
Ontario , Canada
quote:
Originally posted by zoomzoom: speaking of difference betwwen GC and M1..If the thickness of GC over M1 10W-30 is to blame for power loss how would you explain this then? M1 0W-40 produces more power then lighter weight GC 0W-30??? CASTROL SLX 0W-30 SYNTHETIC RPM 3000 3500 4000 4500 5000 Ft-lb 262 290 301 293 272 HP 149 193 229 251 259 Maximum HP: 263.7 @ 4900rpm Maximum Torque: 314.2 @ 3750rpm Oil temp: 175FOil pressure: 43-55psi Water temp: 186F MOBIL 1 0W-40 SYNTHETIC RPM 3000 3500 4000 4500 5000 Ft-lb 268 311 304 300 283 HP 152 207 231 257 269 Maximum HP: 270.5 @ 4950rpm Maximum Torque: 318.3 @ 3700rpm Oil temp: 206F Oil pressure: 52psi Water temp: 190F http://www.performanceoilnews.com/oils_against_oils.shtml
I cant comment on the HP tests, but it didnt surprise me to find them ranking Amsoil as #1 oil with the sponsorship clearly displayed. The HP tests could likely be correct, I think it comes down to friction modifiction of the different oils. Royal Purple has often been listed as having positive effects on HP, there was a test in Hot Rod magazing a year or so ago where some muscle car gained a large amount of power after they swapped Royal Purple fluids in the engine and tranny and diff. I guess its possible if the friction levels are different.
