A couple of years ago I replaced my Subaru's factory ATF with Amsoil ATF. The factory fluid still looked good but the shift quality had deteriorated over a period of just one year so I decided to do a cooler line flush with Amsoil. The Amsoil fluid (original thicker stuff before they reformulated) worked very well in the car's 4EAT transmission - as it does to this day. Since I read that some Jatco manufactured transmission were hard on ATF, I was planning on doing a drain/refill every two years to maintain shift quality.
Well two years and about 28,000km has gone by and it's time to consider the maintenance options. Over here in Vancouver, I can buy Amsoil ATF off the shelf at Canadian Tire for cdn$12/quart. (This is the newer 6.8cst formulation.) I would need about 4 quarts to do a drain/refill on my Subaru. However, I was at a GM dealership the other day and I noticed that they sell AC-Delco DEXRON-VI for cdn$4.35/quart. That is less expensive than I thought it would be and, from what I've read here, DEXRON VI is a pretty decent fluid. If the fluids are compatible, I'm tempted to just do a drain/refill with DEXRON-VI. If the fluids are not compatible I can still do a cooler line flush with DEXRON-VI for cheaper than the 4 quarts of Amsoil would cost me from Canadian Tire. (I need about 10 quarts to do a cooler line flush.)
Your thoughts are welcome,
David
BTW, my daily commute to work is stop and go city traffic. It takes me 1/2 hour to travel the 17km to work for an average speed of 34km/h.
David
