Camry The Beast
Austin,TX
Wow, would love to see faces of those who got smoked by that car, thinking it's another grandma going shopping smile Santa, can you build me same setup? plz. Old setup,singe turbo GT4088R @ 26 PSI 526 WHP and 477 ft-lbs 12.6 @ 121 mph
new setup twin GT28R60's @ 18 PSI 405 WHP and 532 lbft of torque
It has auto tranny frown Tires who knows Here's a list of the current setup on the Camry: Turbo Related/Induction - Twin Garrett GT2860R 0.69 A/R turbos - Tial 44mm Wastegate, boostgate method - Custom sidewinder manifolds - 2.25" Upper Downpipe / 2.5" Lower Downpipe - 68mm Overbored OEM Throttlebody - Precision Turbo 31.5" x 10.5" x 3.5" Intercooler - HKS SSQV BOV - Dual 2.5" exhaust pipes / Supra TT Muffler - Meth Injection System Engine Valvetrain/Top-end - Canadian Cylinder Head Tech Headwork - Catcams Custom Valvesprings - SI Valves 1mm Oversized Exhaust Valves - ARP Head Studs Engine Internals/Bottom-end - 88.0mm DRP Forged Pistons (9.5:1 CR) - Pauter Forged Rods - 3MZ-FE Crank; radiused and balanced - TOGA Oil Pump - ARP Main Studs Fuel System - Racetronix 700cc/min Injectors - AEM Fuel Pressure Regulator - CNC Machined Billet-6AN Aluminum Fuel Rails - Dual Feed -6AN lines and fuel Rail Setup - Walbro 255LPH Fuel Pumps with surge tank - Trickflow Dual fuel filters Ignition - NGK BKR8EIX - Haltech Ignition Modules - HKS Twin Power DLI Ignition System - Chrysler 300M Coil Packs - MSD Voltage Booster Management/Monitor - AEM Standalone EMS (1060 EMS) with Automatic Trans Control - AEM 3.5 Bar MAP Sensor - AEM IAT Sensor - AEM Water Temperature Sensor - GM Knock Sensors at Factory Location - Haltech TPS Sensor Mounted on Stock Throttlebody - Custom Crank Trigger with Motec Hall Effect Sensor - Factory Cam Sensor, shimmed - PLX Devices DM-200 Organic Display Gauges x 2 - PLX Sensor modules; dual Wideband O2's, Trans/Coolant temp/Oil pressure - TurboSmart E-Boost2 - APEXi Turbo Timer Cooling - B&M Cooler 11" x 4.5" x 1.5" for power steering - Factory Hydraulic fan, overdriven - Flex-a-lite 12" S-Blade Radiator Pusher Fan - Thermotec Gold Foil Premium Heat Reflective Material - Thermotec self-cooling heatshielding - DEI Tunnel Shield Transmission/Drivetrain - IPT Fully Built Automatic Transmission (IPT -- http://www.importperformancetrans.com) - Race Calibrated and Modified Valvebody - High Stall Converter (4000-4500RPM Stall) - B&M Hi-Tek Transmission Cooler 10" x 7.5" x 4" Handling/Braking - D2 Racing Coilovers - 13 kg/mm Front Springs; 11kg/mm Rear Springs - Whiteline 18mm Rear Swaybar - Whiteline Polyurethane D-Bracket Bushings - Ractive Strut Tower Bar - Supra TT Front Rotors with CNC relocation brackets - Porterfield R4S Carbon Kevlar Brake Pads - Optima Red Top - Battery Relocated to Trunk - Hella Battery Kill Switch Current wheels: - 17" x 7.5" Volk Racing SE37k, custom powdercoated gloss black Pirelli 235-45-17 Sottozero Performance Winter Tires Lighting - Philips HID Lighting Kit (4100k) - Hella E55 Bi-xenon Projector Retrofit - ZKW Clear Projector Lens - Philips HID highbeams; 3000k - Custom Rewired Bumper Lights With 1157 conversion (parking lights = dim; signalling = bright ) - Front turn signals re-wired to headlight corner lens Cosmetic/Interior - RMM Lower Front Air Dam - Custom Mesh Grill - Ichibahn Automatic Shiftknob - 2001 Toyota Celica Front Seats - 2001 Toyota Celica SRS Steering Wheel - S2000 Antenna Conversion Audio - Alpine MDA-W966J Double-DIN Head Unit - Infinity Reference 605CS Components - Infinity Reference 6"x9" Rear Speakers - JL Audio 250.1 Amp - JL Audio 12W6 Sub - Custom Trunk enclosure retains full trunk space http://honda-tech.com/showthread.php?t=2493536
That's a lot of mods to get beat in the 1/4 by a stock '11 Mustang GT though wink LOL Seriously, a lot of them have been low 12's in the mid teens (115-ish). Ben posted about one going 12.25 @115 stock. Would suck to be the guy with all the mods chasing down (and he would be with that MPH!) the stock Mustang.
Thats alot of work and money for little results. Could of put those resources in an already fast car and be in he 9's
I agree. What a waste of money.
or it's not tuned right. I believe with manual it would do better. Getting it skinnier won't hurt. I think it's someones DD,all seats, big subs and so on, I believe dude is from Canada.( snow, highways and kms instead of miles smile )
I like the idea of a "sleeper Camry" but the thing is, is that want you want? A CAMRY??? Im with ya, i like the ambition and im glad you didnt do the Accord and i like what you have got. But its still a CAMRY!! Do that to an Audi A8............................... (engine work) Or one of the 1997 Range Rover "Special Edition" HSEs with the option package that cost as much as the car or some Subaru Legacy A-spec 2.5 or 3.0 R laugh
I am a frugal builder and get ALOT more Bang for the buck.
Yeah, these results weren't impressive, plenty of stock cars that are faster.
May have saved a few bucks and gotten a similar result with a bolt on nitrous kit. Most of the hp is wasted I.E. Can't put the power to the ground. Watch the steering wheel when taking off, tons of torque steer.
Originally Posted By: tpitcher
My GTO should beat it.
Most any stock Vette could whip it. Also: Cadillac DTS-V (the new 556HP one) BMW M5 etc etc. Any car with "two" mods could give it a run Its a Camry. smile Lexus LS400 the 90s one..
LOL Yep. I have the Vette LS2 engine with a Supercharger, tune & pipes, so, yea. smile
I think you guys are looking at this from the wrong angle. Is a '11 mustang GT faster at the 1/4 mile track? Yes. Fwd cars aren't that great at the track, I know first hand. On a street highway run, the mustang is going to have a hard time hanging with the Camry and probably loose by 3-4 cars length from a 50-120 run.
