Second analysis done on this engine... does not look good to me. Engine was overhauled at 199100km, oil changed at 200100. Mileage now 208400, engine in use 8300km (around 5200 miles). I have an engine monitoring system that tells me the engine has been running about 150 hours since the last change.
The overhaul was basically everything - new cylinder liners, pistons, rings, big-end bearings. Injectors were serviced and cleaned.
The previous sample was for only 2000km, and when the engine was using a lot of oil (before the overhaul). The current sample was taken after a long and very dusty 6500km through Africa.
UOA was done at a place called "Wearcheck" in South Africa. They say:
All wear rates are high even for bedding-in. Higher than normal silicon (dust) level in the oil - check air intake system for leaks and for defective oil filler cap, breather or dipstick and dipstick holder. 4.5% Fuel dilution taking
place - check fuel system for malfunction. As a precaution check for low oil pressure. Check that blow-by is not excessive. Change the oil and oil filters. Check oil filter for abnormal wear particles.
(first column is newest sample)
** Wear metals
Iron 44 21
Chromium 10 1
Nickel 1 1
Molybdenum 146 2
Aluminium 16 5
Copper 11 7
Tin 11 1
Lead 112 10
PQ index 10 15
** Contaminants
Silion 31 8
Sodium 22 4
Manganese 9 3
Lithium 3 0
Soot 0 0
Oxidation 19 16
Sulphate 26 25
Nitrates 11 11
Fuel % 4.5 5.5
** Additives & Lubricant condition
Magnesium 315 21
Calcium 2224 2455
Zinc 901 1241
Phosphorous 740 1060
Barium 0 1
Boron 118 2
Sulphur 3832 11570
TBN >6 >6
** Viscosity
cSt 40 degrees Celcius 125.8 80.8
cSt 100 degrees Celcius 15.8 12.2
Obviously the high wear metals, silicon and fuel dilution is worrying me, but what is attributed to recent overhaul and dusty conditions?
Why is the newest sample's viscosity spot-on (it is almost exactly the same as the TDS of Delo 400) with 4.5 % fuel dilution?
** Wear metals
Iron 44 21
Chromium 10 1
Nickel 1 1
Molybdenum 146 2
Aluminium 16 5
Copper 11 7
Tin 11 1
Lead 112 10
PQ index 10 15
** Contaminants
Silion 31 8
Sodium 22 4
Manganese 9 3
Lithium 3 0
Soot 0 0
Oxidation 19 16
Sulphate 26 25
Nitrates 11 11
Fuel % 4.5 5.5
Magnesium 315 21
Calcium 2224 2455
Zinc 901 1241
Barium 0 1
Boron 118 2
Sulphur 3832 11570
TBN >6 >6
** Viscosity
