Hi.....I'm hoping some of the Chemical Engineers here can look at this info I found in the link below.
Will this work by bubbling Butane or Propane into stale gas?????
Other than water contamination and fuel (volatility????) what other components of the fuel do I have to worry about?.
I left my car sit with about 1/2 tank of gas for a few years after becoming ill. It sat in a humid parking garage of my apt. building by the ocean in Fl.
Short of draining the tank which is gong to be hard due to my underlying health, is there any additives that will remove any water and/or rejuvenate this fuel to be run by idling the car, or will this procedure work above?
I can probably and easily try to drain the tank by doing a simple by-pass pump activation, and pump the fuel into a container, and/or maybe a good siphon, but this is in a 1990 Cadillac Brougham and it's probably got 10+ gal. of gas.
Letter Re: Refurbishing Dead Gasoline - SurvivalBlog.com
JWR, The shelf life of gasoline is one of the lurking problems with the prepper community. With this short article I will show you a simple process to take that lifeless gas and make it usable again. One of the issues with very old (several years) gas is the formation of deposits and gum via...
survivalblog.com
