Calcium vs Moly as a friction modifier?
Missouri
Which is better...? Brands such as Pennzoil Conventional and Havoline continue to use higher levels of moly, while other brands seem to lean more on calcium. Yet, the brands with the moly seem to have the same level of calcium as those with no moly. So, is it better to have both, or one or the other?
FM = friction modifier
AW = anti wear
Your header is "Calcium vs Moly as a friction modifier?"
While both Mo and Ca can be a multipurpose additives, Ca is not typically added as a FM, and lots of times neither is Mo and the body of the post implies you are talking about them as AW agents.
Hmmm...perhaps I should have put it in more simplistic terms since even I am confused.
Are oils with no moly in them just as good as those with it?
Castrol GTX 5w30 and 10w30 and Valvoline 5w30 and 10w30 as an example have no moly.
And those are fine oils. For years Amsoil had NO moly (some variants still don't) and those oils were fine. You can't simply say anything about an oil by looking at one or three constituents. It's just not that easy.
So then, why does Valvoline make a big deal out of it? Once I was speaking to a rep and he was explaining how great their Maxlife is because they use moly
Pleasde read this post and look at the various additives for each application or spectrum of applications:
https://bobistheoilguy.com/forums/threads/additives-xii-multifunctional-additives.41173/
There are many chemistries for friction modification, anti-wear, and Exreme pressure.
Moly is but one of them. In low concentrations, it acts as another friction (reduction) modification additive, in medium concentrations it acts as a friction modifier and anti-wear, at high concentrations it acts as mainly as an EP agent. There is nothing majic about it, it works, just like ZDDP.
