ok, some bypass filters are supposed to be changed every 5K miles, some are supposed to be changed every 10K miles, but wouldnt it make more sence to only change it when it is dirty? lets say your filter is capable of going 20K before it gets clogged and reduces flow. but you change it anyways at every 5K because thats the suggested interval. well i was thinking about this and if i used a length of clear high pressure plastic tubing (similar to the tubing for remote oil pressure guages) so that i could see the flow of oil, and only change the bypass filter when i see the oil flow slowing down.
how would i test it?
every morning before i start the engine the bypass filter clear plastic inlet tube has drained dry from gravity. so as i start the engine i would watch the tube fill up with oil, and when it gets enough mileage that it slows the flow i would see each morning on inital startup, then i would know its time to change the filter.
what do you guys think of my idea? im espically curious about ralph woods comments. i think this could go a long way to offsetting the price of a bypass setup. if i could get by changing the filter only when its clogged.
