After much thought I have decided to add a Motorguard lube, ATF and fuel filter to my 2005 Chevy Silverado, 5.3L.
I am rookie and need understand on a few more points.
Which sandwich adaptor do I need for the oil? I have read some vehicles have a relief valve in the filter housing and some in the filter does that matter when choosing a sandwich adaptor. What is a relief valve?
Is my understanding that with the Motorguard ATF filter, I break the cooling line going to the cooler and splice in the Motorguard? ie. All the oil goes thru the filter.
Is there a problem starting the vehicle after a fuel filter change? I am just wondering if the vehicle can burn the fuel in the line then run out for a moment because the Motorguard needed time to fill up again. I suspect this is a mute point and it’s just like changing the OEM filter.
This brings up another thought; do I install the filter before or after the OEM filter?
I have read you need to change the lube oil filter every 2000 miles, when do you change the spin on filter?
How often do you change the ATF and fuel filter?
Your help in this matter is much appreciated.
Bruce
Bruce
