I’m trying to press bushings into the rear upper control arm of Jeep #2. For those of you unfamiliar, it’s about 30 lbs and 3.5’ wide and about 1.5’ deep. Imagine a short wife v. The 2 “tops” of the v get the bushings while the bottom is bolted to the rear axle housing with a ball joint. Anyways, it’s so cumbersome I can’t hold it square while pressing in the bushings.
Is there a shop press jig or bushing driver set anyone recommends? I see different sets on eBay with different sized pieces. They look threaded so no issues with holding a monstrosity square.
