Originally Posted By: Trizzy
Do any of you think that worn out Valve Guides could be the issue and is there a way to fix it without re-doing the whole head/engine? Maybe thicker oil? Or will Kreen still work?
Any car can have any mechanical problem, so i would be guessing. The main reported problem on the 99-01 1zz-fe 1.8L engine (mine included) is massive oil consumption from clogged oil return piston holes. Happens quite easily using cheap dino and neglecting timely oil changes. Holes are too small, not enough of them, near a hotspot.
Repeated cleanings are your only hope other than teardown. Its a shame a major engine teardown is required for 5 mins of drilling, enlarging, and adding a couple of oil holes to the pistons. Once you break the engine down to that extent, you may as well rebuild.
Repeated Kreen piston soaks, running it in the oil are an option that may work. Using a good synthetic oil also may clear them over time. Until the holes are cleared you will consume oil no matter what you use. At least if your using synthetic, your making an attempt to resolve it. Cheap thick dino = dead end.
I'm currently running T6 and then Kreen at the end of the OC, too early to report results.
Clogged Holes
Holes enlarged, cleared, additional holes added
