Originally Posted By: Superbuick96
Originally Posted By: dan3952
I wouldn't bother with the MaxLife blend, I used it before on my Acura 2.3 and it burned as much of that as with any of them. It helps to swell seals and is bit thicker, but depending on your problem may not be a magic bullet for your oil burning. I suspect mine has moderate ring and valve guide passage of oil which is not correctable with anything because there's metal that's worn away. I would just stick with the Pennzoil HM product. 1 quart in 4k is nothing anyway I probably use a quart every 1500 miles
I use MaxLife Blend, with great results, absolutely no burning. I wouldnt write it off because your Acura didnt take to it. The 2.3Acura/Honda, and the 4.0 AMC are different animals.......I been wanting to try the Pennzoil HM as well, but It just seems wrong to stop using VML if it works so good for my application....
LOL & I like Pennzoil HM too but am gonna try max-life...you might as well try the Pennzoil
