i saw some folks viewing this forum and hoped someone could answer quickly. i'm in the middle of a project and could use some info right away. i've turned up little to nothing on a search.
quickly...
i rebuilt the top end of my '92 4rnr and this evening completed. went to add the oil back in, realized i overfilled, drained to start over, and discovered bubbles in the oil....plus a slight greenish tint. i noticed when i drained the oil it came out very dark at first, meaning i hadn't drained the oil when i started the rebuild. could have swarn i did. that was over a month ago when i started the project. anyway, the oil i added tonight was synthetic Mobil 1. should be compatible with conventional, right? it is cold, the original oil is dark and aged and has been sitting. could these be the possible causes for the bubbles...the mixing and the age?
and what of the tint? i figure the oil just has to be rather broken down because no headgaskets leaked and no coolant got in the block during the tear down. if any did, it was very, very little...but, i'm pretty certain that couldn't have happened. anyhow, can anyone offer some suggestions on the oil. i just want to use it to crank the motor and test it for success or failure on the rebuild....see if it runs.
hope this isn't a stupid question.
thanks
quickly...
thanks
