I was trying to change and bleed the brake fluid on a 98 avenger. I ended up breaking one of the valves.
I guess it's no big deal, just means I can't bleed that one caliper and since the valve was never opened. I am in no big trouble.
Is there replacement for a valve or do you have to replace the entire caliper?
Also I overfilled the reservoir with fluid because fluid was pushed out everywhere when I closed the cap. Should this be a concern?
[ May 16, 2006, 09:35 PM: Message edited by: zimmerDN ]
