Originally Posted By: ahoier
Originally Posted By: jorton
Open the brake fluid reservoir only when pads/shoes are replaced because if you see the level at the min line it's time for new brakes.
This is what I've heard too.....at least on my "previously owned" new cars....
Manual stated the brake fluid didn't need "top offs" since the fluid level will go down as the brake linings wear out....Or, obviously if you have a leak (i.e.: takes more distance to get the car to stop...).
BUT, the Hayne's manual for my 88 says it should be checked once a week lol....aside from that, 80k seems a bit low for brake replacement.....? Could be a lot of stop and go/city driving I suppose though?
May as well change out (whether exchanged, flushed, whatever you wanna call it) all fluids, Power Steering, Transmission (dont forget the filter), radiator, etc...
FWIW I am ASE certified in Brakes and Suspension / Steering and I was taught to NEVER top off brake fluid. The level on a vehicle with disc brakes can indicate friction material thickness and also rotor thickness to some extent.
Now with that said, if the brake fluid is truly horrible and is in dire need of replacing and the friction material and rotors are nominally thick, go ahead and flush the fluid. The fluid is that condition obviously has a lower boiling point and is not safe.
When I do brake jobs I evacuate the master reservoir to below the minimum level before I compress the pistons back in to prevent the fluid from shooting out all over the firewall (ask me how I know). I will do a full flush of fluid when I replace friction material as well. I have a Vacula for that and the cars I maintain have Speed Bleeders. I will use the Vacula then follow up with a manual bleed until the pedal feel is to my liking.
I usually only get 2 years or so out of a set of friction material, sometimes longer. But I usually replace friction material when they are just over the thickness of the backing plate. Just a weird pet peeve I have, also it is no fun failing tech at a track day because your pads are less than 5mm thick. Anyone who gives a % of friction material left should not be listened to as that is not the proper way to report friction material thickness. The only way you can possibly do that is with knowing exact thickness prior to installation.
