Brake, Power Steering, Tranny Fluid Extractor
Home-made Mityvac. May be good for extracting small amounts of tranny fluid but not a pan full of fluid.
Those hand pump/mityvac kits are really nice to have around for a whole bunch of applications.
I don't use the supplied fluid reservoir though, seems too small. I use a jar I drilled two holes in and put in a couple barbed ends. Let me pump in a lot more fluid
Need to invent something like that but without a small jar. A gallon sized jug would work. No hand pump but an electric tire pump with a toggle switch or a bike pump..
When I extract ATF from my truck I use the same setup but remove the hand pump. Then I take the hose from the hand pump and hook it up to my vacuum cleaner. Quick and easy...no hand cramps. I need to find a bigger bottle.
