When pulling out of the driveway or slowing down in traffic, the pedal is fine. When sitting at a light, the pedal will drop to the floor and I'll have to push harder to stop the car from rolling.
I have no idea if this has any bearing on the problem, but the rear calipers make a clicking noise when I apply the brakes. I can only guess that it's b/c the caliper slides need lube.
Have the cups in the master cylinder gone bad or did I introduce air into the system when bleeding the brakes?
Fluid is new (flushed it a few months ago), but the old stuff was in since it was new (9 years). Didn't have a problem until recently.
I don't have the time to replace it myself, so I'll most likely pay the dealer to do it, if the MC is indeed the problem.
Is there any test I can do with my limited abilities that will prove conclusively that something is the problem?
Thanks in advance.
Thanks in advance.
