I have a 2000 Crown Vic with ABS and Trac Ctrl, and 4 wheel disc brakes. I have found that my right front brake will grab and lock up the tire when I apply the brakes on a slippery surface. The left front brake won't do it.
I have less than 23k miles on the original factory calipers and rotors. The pads are about 20k miles. However, the factory pads sort of grooved the rotors and that was part of the reason why I got new brake pads.
I have lubed the caliper slide pins in the past and I checked the rotor surface and brake pads to see if anything was wrong. I can't figure out why it grabs more than the left side and why ABS doesn't kick in.
It also pulls to the right when I get on the brakes. Otherwise the car tracks straight on a flat road.
