use
i bought one of the brake fluid testers off of AMAZON. I tested the crv and sub which has under one year fluid. tested the bmw that has not been changed for 10. on the sub and crv they show 1% . odd to me seeing the fluid in both was under a year. maybe because they live outside might be a factor in the 1%.
what was also odd is the bmw also showed 1% but its been garaged all of it life
also what is the correct way to use it. some say just need to immerse the probes in the fluid.some say it must be immersed till it touche the plastic end . doing one or the other gets diffenrt results
https://www.amazon.com/KINGBOLEN-Brake-L...#productDetails
