The truck is and 89 GMC S15 (the little one) Jimmy. 4.3 V6, unknown mileage but believed to be over 150,000 miles. Automatic transmission, 4x4 and loaded with options. I picked it up as a winter car from my father, but it has been sitting for a couple of years. As far as I know, it runs pretty good (fast idle is stuck, so I have to chase that down this weekend) but probably hasn't had any maintenance in a long time.
My thoughs are this:
1 - change the oil and filter with some HDEO and ARX
2 - do a drain and fill on the transmission with a filter change. At the same time drain and fill the transfer case and diffs.
3 - lube all grease fittings.
4 - pull the wheels and check the brakes.
5 - drain and flush the cooling system.
Is there anything I missed? Anything I should be aware of? I would like to get it road worhty again and start driving it in the next month or so. Any tips or advice would be greatly appreciated!
